help 94 honda accord speedometer
Old Feb 17, 2008 | 03:45 PM
tonymazz's Avatar
tonymazz
Default help 94 honda accord speedometer
my speedometer not working d-4 is flashing
Old Feb 17, 2008 | 06:29 PM
Fuse's Avatar
Fuse
Take a look at your vehicle speed senser (vss) its on the back of your transmission on the top side its a 3 wire connector. See if it is plugged in. If it is the sensers are common for failing. It can also be one of the 3 wires is cut or shorted to ground it can also be a bad transmission control computer but thy don't fail that often.
Old Feb 18, 2008 | 05:36 AM
tonymazz's Avatar
tonymazz
thanks i"ll check that
