2006 Honda Accord V^ water pump DIY??
2006 Honda Accord V6 water pump DIY??
Car took a small hit in the radiator and after replacing the rad and fans a coolant leak revealed it self from under the timing cover, I'm guessing it's a water pump...
Are there any diy's on replacing this item?
lots and lots of fail
1 Post
Or Amazon, thats where I got mine.
You're treading on very, very dangerous waters not applying the correct torque spec to any of these bolts, especially the WP, crank pulley, engine mount and P/S pump.
Even with a $200 craftsman air gun (600lb/ft to break the bolts loose) the bolt won't budge.
Anybody know if this is a normal thread or reverse?
