Engine problem: '91 Accord EX
Old Oct 18, 2002 | 04:45 PM
Experimental's Avatar
Experimental
Default Engine problem: '91 Accord EX
I started having this problem with my accord a couple of weeks ago. I will start my car, let it idle for about 5 minutes before I start driving to warm up. At this point, the car is fine. I drive out of my neighborhood and I will start to get a popping sound and loss of power.
The popping sound seems like its coming from under the hood from inside the car, but from the outside sounds like its coming from the exhaust. Its not exactly a backfire (shotgun) sound, but more of a muffled popping. Sounds like popcorn in a microwave! It also wont allow the tranny to shift, not to mention it wont allow it to rev much.
It will consistently do this for a while, at this point it will idle bad, and almost want to die. BTW, it does not give me an engine light anytime in the process. When it finally does...the problem is gone!
I have done a tune up (plugs, wires, cap, rotor), timing belt has been changed along with the waterpump of course.
Does anyone have any ideas? I really would like to be able to fix this myself if possible. Any help would be appreciated.
Brian
Dreamsmine@aol.com
Old Oct 18, 2002 | 04:48 PM
SumAccordGuy94's Avatar
SumAccordGuy94
Older Honda Fanatic
almost sounds like water in the gas... :dunno:
Old Oct 18, 2002 | 06:24 PM
Jeff TYPE R's Avatar
Jeff TYPE R
Crazy AE86 dude.
lol yea, made any enemies lately?
Old Oct 18, 2002 | 07:14 PM
REbornHONDAneer's Avatar
REbornHONDAneer
Honda Biased
egr port problem? :dunno:
Old Oct 27, 2002 | 09:24 AM
Experimental
Alright...got an update.
The EGR ports were blocked so they were cleaned. The PCV valve was clogged, and in turn crushed the tube going to it because of the build up of vacuum. Thats all fixed up. New fuel filter, reset the idle mixture, timing belt, and balance shaft belt.
AND...it's still doing this!
Anyone got ANY ideas? The mechanic can't even figure this thing out. I really need some help.
I really miss my ride!!!
Brian
Old May 28, 2003 | 12:09 PM
GreenEX's Avatar
GreenEX
A bad catalytic converter can shoot the beads out of itself into the exaust system, making you wonder where the hell the noise is coming from. I had that problem a few years ago, and had to replace the converter, and entire cat-back system.
Old Jul 1, 2004 | 12:05 PM
Experimental
Thought I would follow up. Turned out to be an O2 sensor...PITA.
Old Jul 1, 2004 | 01:43 PM
honda530's Avatar
honda530
www.HondaShowOff.com
hehe i was just about to post up that it sounds like a bad 02 sensor It happened to me and it was the 02 sensor.
Old Jul 1, 2004 | 01:47 PM
flyromeo3's Avatar
flyromeo3
damn the sensor will do all that?
Old Jul 1, 2004 | 01:59 PM
honda530's Avatar
honda530
yeah man lol. At least he only has 1 to deal with lol. damn ob2.
