94 Accord climate control switches
Hello,
I have a 1994 Accord that has developed a problem with the climate control switches. No matter which switch is pressed, the air comes out of the dash vents. The big problem is that in rainy Seattle, No defroster!!
The lights still come on when different selections are made. The AC works when the AC button is pressed. And the fresh air/recirculation selection seems to work fine.
Any ideas?
Thanks!
Any ideas?
Thanks!
Hello,
Any ideas?
Thanks!
Any ideas?
Thanks!
ur switches are loose from inside, the solder broke, if u can, remove the switch, tear it apart and resolder all the connections.
