Camber issue....
Old Dec 27, 2007 | 08:12 PM
msand9898's Avatar
msand9898
Default Camber issue....
Ok I have a 1993 accord that needs the camber adjusted (forgot what the tech told me)
When I look at my car from the front, the top of wheels are slightly tilted outward?
I've gone thru 2 front tires in the last three months because they are getting worn from the outside only...
The car does track straight if I let off the steering wheel, so with that being said; how do I adjust the camber as my budget is zero (christmas maxxed out all cards)?
Old Dec 27, 2007 | 09:31 PM
nspec_Cd5's Avatar
nspec_Cd5
y do u have a positve camber in the first place? is ur suspension modified in any ways?
if ur suspension is stock then the only reason why u have a camber issue is that u have something bent in there.
Old Dec 28, 2007 | 06:44 AM
losiglow's Avatar
losiglow
That's wacky. You must have hit some pretty hardcore curbs or something. I've adjusted the toe on my 93 but I'm not sure there's an easy way to adjust camber. You could take it in and get a quote. It might not be that expensive though you'll probably have to get a 4-wheel alignment too.
Old Dec 28, 2007 | 04:47 PM
nspec_Cd5's Avatar
nspec_Cd5
take it to firestone and have them do alignment on it, they'll tell u right away whats bent in ur car
