03 Accord Rear Door Panel
One rear electric window is not responding. I hear a relay click, but no response from the motor. Any instructions for openning the rear door panel on an 03 Accord LX (no side air bags) would be greatly appreciated. Also, is each electric window separately fused or is there just one fuse for all window motors? Thanks for your help.
they're very easy to remove.
sorry i dont have any instructions in pictures, but there're only a few screws. One behind the door opener, the other is usually in the door handle.
I think when u get the screw out of the door opener, u'll have to slide the cover towards the front of the car adn then pull it out.
When u get those two off look for other screws or clips that u can take out from outside.
Other then that, its all clips that hold the panel to the door, Pull on the panel from bottom and the clips will start popping out.
