98 Accord - System too lean
Old Mar 13, 2008 | 08:26 AM
kobayashiz's Avatar
kobayashiz
The first things I would try if my car was running too lean would be the checking the intake tract for leaks and changing the fuel filter.
k.
Old Mar 14, 2008 | 12:30 PM
riaz1390's Avatar
riaz1390
Thanks K.
I had the mechanic check for Vacuum leaks around the throttle body but no leaks found ... I will change the fuel filter now ... I can't find it on the fire wall or even in the fuel line. I have a 98 Accord EX ... does anyone know where to find it ? Thanks !
Old Mar 14, 2008 | 02:45 PM
kobayashiz's Avatar
kobayashiz
Based on my experience with an earlier accord Id look behind the engine low on the firewall.
k.
Old Mar 14, 2008 | 03:37 PM
nutz's Avatar
nutz
check your voltage to the fuel pump and if you have really good ground
