Noise in one wheel;ABS?
Old Dec 3, 2007 | 12:00 PM
Korruptor's Avatar
Korruptor
Default Noise in one wheel;ABS?
Hello guys,
I did a few searches prior to this post but i couldn't find someone with a similar situation.
Here is the problem:
As I drive there is a repeating light knock in the passenger side rear wheel. The tempo of the knock follows my speed. When I brake the knocking gets very loud (sounds almost like a semi's Jake brake from the inside). Any thoughts on what is wrong?
My ABS light is ON.
I have tried removing all the ABS fuses & relay but the problem remains (the dash board light stays on as well).
I have no code.
Fluid levels look fine.
Only one wheel is affected.
At the very least I wish to fully understand the problem so if I am forced to bring it to a shop (vs doing it myself) I won't get burned.
Any thoughts on what the problem might be?
Thanks
Old Dec 3, 2007 | 01:57 PM
Korruptor's Avatar
Korruptor
I was thinking might it be a seriously warped rotor?
Old Dec 4, 2007 | 08:25 PM
JimBlake's Avatar
JimBlake
I was thinking that we have no clue what model-year or engine-type you have, or even what country you live in.
