Gas consumption question
Old Nov 22, 2007 | 07:25 AM
flyromeo3's Avatar
flyromeo3
Default Gas consumption question
LAtely, i've been noticing my car has been consuming a lot more gas.
I fill up my car with gas the other day and half way between full and mid on the gas gauge I noticed my traveled mileage was 76miles. I now have about 146miles driven on this tank and am a bit below the half way point on my gas gauge. On my moms sUV I notice its consuming more gas than usual and she only uses the car to go to work, supermarket and back home.
Has anyone else noticed this with their car?
I dont have a heavy foot and am not sure what else to do.
YEs I searched and mostly everyone says to do a tuneup which i've done like 3 weeks ago.
Old Nov 22, 2007 | 07:38 AM
nspec_Cd5's Avatar
nspec_Cd5
here's a way to find out
fill up all the way, reset ur mileage counter, then wait untill the tank is half way empty.
then go back to gas station, write the down how many u drove, then fill it back up and divided the mileage u drove by the amount of gallons u put in.
another thing u gotta watch out for is people mixin water w/ their gasoline, they cought a few gas station owners doing that here in houston.
earlier this year, my car was givin me 11mpg and after changin out the o2 sensor (even though i didnt have any CEL), it went back up to aournd 17-18mpg, and thats where it stays for me.
Old Nov 22, 2007 | 07:47 AM
flyromeo3's Avatar
flyromeo3
ive never changed out my o2 sensors. im at 143k miles too, is that something i should consider changing? Even though there is no CEL?
Old Nov 22, 2007 | 07:52 AM
nspec_Cd5's Avatar
nspec_Cd5
yeah, get a regular o2 filter on ebay for 50 bucks, but u'll have to tap the wires urself, will save u like 100 bucks.
Old Nov 22, 2007 | 07:58 AM
flyromeo3's Avatar
flyromeo3
cant find any filters on ebay...maybe no one is selling them yet.
searched for:
o2 sensor filter
o2 filter
Old Nov 22, 2007 | 08:28 AM
A-series's Avatar
A-series
v-card member alpha
Colder weather will reduce mileage a little. If you let the car idle and warm up it will be even worse of course (0mpg when not moving)
First thing to check is the air filter as it seems to be the most commonly overlooked cause of decreased mpg(probably already have if did a tune up).
Next Id try some fuel injector cleaner myself, not only will it help clean up the injectors but you might have carbon build-up on the exhaust valves which reduces compression and allows the fuel & air mixture to vent past the valves before ignition even takes place(means more gas because you have to push the pedal farther just to get going or maintain speed).
Cars that burn oil, even if there's no smoke but a little oil use, will develop those blow-by symptoms much faster but any car can have some build up over time. Depends on the quality of gas you get as well, I stick to places like Shell or BP.
If a tank or two of that doesn't help noticeably I would check the ignition timing.
Old Nov 22, 2007 | 08:52 AM
flyromeo3's Avatar
flyromeo3
I think im definitely going to use some fuel injector cleaner. ill buy some tomomrrow. I wanted to try that sea foam but not sure if its worth it at this point since I have 143k miles. Maybe the gunk thats in there is holding my engine together....who knows..
I know when i go to the oil lube place they always try to sell me an engine flush since they say i have dirty oil when draining. So I've been changing my oil more often just to see if it cleans things out.
I removed the valve cover and didnt notice any slug around the cam and valves so i think the are b.s'ing me.
Thanks for the suggestions....
Old Nov 22, 2007 | 09:24 AM
nspec_Cd5's Avatar
nspec_Cd5
I'm fuckin sorry man. its not filter
its o2 sensor
a big typo
is it for that 02 accord? 4 cyl or v6?
Old Nov 22, 2007 | 09:26 AM
nspec_Cd5's Avatar
nspec_Cd5
Oh yeah, get a chevron techron fuel system cleaner from autozone. that shit really works
Old Nov 22, 2007 | 10:00 AM
flyromeo3's Avatar
flyromeo3
its o2 sensor
a big typo
whas the OEM brand sensor , Denso?
its 4cyl auto. I guess Ill need two of them? one by header and the other by the cat?
