1993 Accord Small lights fuse keeps blowing
I have read that the "Small Lights" fuse protects the Dash Lights, Tail Lights, Front marker lights, Glove box light, Ash tray light ans Cigarette lighter light.
I have disconnected all front marker lights, both rear light cluters but still blow the 15Amp small light fuse when I turn the headlight switch to the first position. I cannot remove the dash to check that light.
Any other things I should check?
u dont have to remove the dash to check this out. u may have to remove the bezel that goes around the gauge cluster and down the console to remove the stero and other console components and get to some of the wiring. i changed out my cluster a few months ago and i cant remember what wiring is in there but there is alot.. i dont remember where the dimmer switch wiring is located. do a search.. also check on www.cb7tuner.com that is for the 90 to 93 accords forum.
