Front brake pad replacement
Old Oct 12, 2007 | 09:02 AM
Dave Daiker's Avatar
Dave Daiker
Default 2003 Front brake pad replacement
Can anyone tell me if changing the front roters is neccesary when replacing pads on a 2003 Accord with 87000 highway miles. Original pads are on the car with no vibration when braking. Learned that the rear calipers have to be screwed in to compress, but not sure on front. Any insite would be appreiciated, have heard that new aftermarket rotors are almost as cheap as turning. Also is it hard to remove the rotors, any tips.
Old Oct 12, 2007 | 09:58 AM
v6_accord_jerz's Avatar
v6_accord_jerz
Stupid Power Ball
You should be fine. Usually rotors need to be replaced at decent high mileage or when the owner wears down the pads and brake metal on metal causing cuts into the rotor. Just check for an abnormal cuts into the rotor, otherwise you'll be fine just replacing the pads.
BTW if you're looking into rotors, brembo is a great brand and not too expensive either.
Old Oct 12, 2007 | 10:36 AM
Dave Daiker
Default Thanks for info
Is my daughter's car, my old one. Just want to make sure she is safe. I have a new 2007 V6 I love.
Old Oct 12, 2007 | 10:52 AM
v6_accord_jerz
Stupid Power Ball
Nice! Yea your daughter should be fine. You can change the rotors the next time you change the pads.
Welcome to the board. :thumbup:
Old Oct 12, 2007 | 11:22 AM
DakarM's Avatar
DakarM
rotors have the min. thickness stamped somewhere on the rotor. buy a cheap caliper with standard measurements and measure the thickness. simple 20second check can save you headache down the road.
'00 Dakar Bus CRS Edition
LCD Squad #0001
Originally Posted by WiLL
