electrical---95 accord
Old Oct 8, 2007 | 03:14 PM
tdonley's Avatar
tdonley
Default electrical---95 accord
ok, well a few years ago my honda accords lights went out (dash) all the lights excptlike the a/c indicater or the clock, etc...
well yea when i put on the head lights they go out.
then about 2 years later the retractable antenna broke (theres still an anttenna it jus doesnt go down) and it makes the buzzing noise it would typicaly make but doesnt move,
then recently my locks went out , (power locks) and the back door lock jams so you cant lock it.
our 500 dallar camera got stolen recntly too
:doh:
please help my honda
Old Oct 8, 2007 | 03:15 PM
tdonley's Avatar
tdonley
its an EX btw
Old Oct 9, 2007 | 11:39 AM
idol4232003's Avatar
idol4232003
:doh:
have u checked the fuse(s)? they're usually right beside the footrest on the driver side.
for the power antenna unit...it's just a motor attached to gears, which attach to a plastic line with teeth, to pull the antenna in/out. either that line broke...or it's not aligned with the gears. u can disassemble it to check. if no longer repairable, then shop around the net or local junkyard/dismantler.
for the $500 camera...sorry dude
Old Oct 9, 2007 | 08:28 PM
tdonley's Avatar
tdonley
Default thanks
well i checked the fuses about a few weeks ago and checked the fuse map and didnt see anything about the power locks
and for the dash lights.... if you like punch the door or above the spedometor they flicker on for about 5 seconds then off:madr: :madr: :madr: :madr: :madr: :madr: :madr:
Old Oct 9, 2007 | 08:29 PM
tdonley's Avatar
tdonley
Default anttenna
thx 4 the tips, i was trying to think how they were assembeled and had no idea im gunna check that out
Old Oct 10, 2007 | 10:09 AM
idol4232003
oh..and be careful when disassembling..i think there was a spring in there that popped all the parts out as soon as i opened the casing i had to spend more time figuring out which part goes where afterwards
Old Oct 10, 2007 | 01:08 PM
tdonley's Avatar
tdonley
Default ....
how many parts:squint: :nervous: and if thats the case i might jus leave it alone
Old Oct 10, 2007 | 01:29 PM
idol4232003
i dont remember exactly...it's been a while...but shouldnt be much...i think just a couple of gear wheels, a magnet, and a couple of springs to provide tension. not really that difficult, just tedious to put back coz the pieces are so small...just make sure the magnet is put back the right way coz wrong polarity will reverse the direction of the antenna (i.e., IN instead of OUT). if ur gonna replace it anyway, might as well open it up, right?
Old Oct 10, 2007 | 01:32 PM
tdonley's Avatar
tdonley
ur right, after all if i mess up jus bring it to the pros,
