D4 and maintenance light are flashing
Old Sep 29, 2007 | 03:45 PM
Jorgexx's Avatar
Jorgexx
Default D4 and maintenance light are flashing
I have a 2001 accord lx and the D4 light flashed a few times once but ever since then the maintenance light has been flashing 10 or 11 times everytime I start the car, I'm guessing its time to change the transmission fluid since I've already done everything else related to maintenance I could thinnk off, does anyone have any recomendations as of what fluid works better for accords?
Old Oct 1, 2007 | 08:39 AM
v6_accord_jerz's Avatar
v6_accord_jerz
Stupid Power Ball
The maintainance light usually flashes periodically, regardless whether or not maintainance has been done, just needs to be reset. As for the flashing D4, yea I would change the tranny fluid and see if that solves the problem. Remember to use only Honda ATF and just "drain/fill", never "flush".
Old Oct 3, 2007 | 08:01 PM
00exAccord's Avatar
00exAccord
Former Dsmer
i had that happen to me in my accord it turned out that my trans went bad and honda extended the waranty on just the transmission to 100,000 miles
Old Oct 4, 2007 | 04:42 AM
flashing D4 = transmission failure.
get it inspected asap
Old Oct 11, 2007 | 11:56 AM
PHAT97EX's Avatar
PHAT97EX
Mine did the same thing; D4 light flashing and CEL on. Car would not shift from 2nd on up. Found out it was a bad Counter Shft Speed Sensor. Diagnosed and fixed for $85. V6 accord Jerz is right ONLY use Honda ATF and drain and fill-not flush!
