Front oxygen sensor for 96 accord
Old Sep 24, 2007 | 12:33 PM
atlantamike's Avatar
atlantamike
Default Front oxygen sensor for 96 accord
How do I replace the front oxygen sensor on a 96 Accord (code PO141)? How hard is this to do? Any special tools required? Thanks, guys!
Old Oct 13, 2007 | 11:07 PM
buddhabus's Avatar
buddhabus
Honda Lover
Its very easy, and very visible because its almost in front of you when you pop the hood. You need a 02 sensor socket and wrench. After you install, clear the codes and youre all set. Advisable to get OEM o2 sensors not the universal kind.
Old Oct 14, 2007 | 05:16 PM
wales78's Avatar
wales78
IIRC, you will need a really big cresent wrench. Obviously a socket won't work. I used a really big pair of pliers because I didn't have the right size wrench. Also, you will need to move the heat shield out of the way. Big pain to remove it completely--just loosen it and move it out of the way. It's an easy and obvious repair. You might put a little anti-seize on the threads.
