honda accord problems
Old Sep 8, 2007 | 10:10 AM
S.A TEXAS 14's Avatar
S.A TEXAS 14
Default honda accord problems
Need Help To How To Turn On My Honda Accord Lx 1987 With Out The Key Because The Car Has Bin Sitting On My Back Yard For 2 Years And The Ignition Switch Broke And Need New Way To Turn It On Any Ideas
Just Message Me Plz
Thank You.
Old Sep 8, 2007 | 10:44 AM
nspec_Cd5's Avatar
nspec_Cd5
i dont know if it has a mechanical key lock or not.
but can u acsess the ignition wires? if yes, then get a tester and see which ones are constant 12+. take connect the 12 volts to each of the wires that did not have 12 volts.
u'll actually end up using 3 wires in total. one will the constant 12+
the second will be the one that turns on all ur electronics in the car (meaning when jump that wire w/ teh constant, it will light up ur speedo and etc.)
ok connect teh constant and the second wire (keep them connected in a way that they dont lose the connection)
then connect ur starter wire w/ the constant which will start ur motor.
if everything is right. it'll start up.
the third is the one that runs ur starter (when u jump it w/ constant)
Old Sep 8, 2007 | 10:45 AM
nspec_Cd5's Avatar
nspec_Cd5
and yeah. if it has a mechanical steering wheel lock, then u wont be able to drive the car around, u steering wheel will be locked in an angle
Old Sep 8, 2007 | 11:15 AM
S.A TEXAS 14
yeah thanx for the advise am going to try that and i was able to take the steering wheel lock off.
