P1166 and P1167 diagnostic code help
Old Aug 27, 2007 | 08:47 AM
mainiac2's Avatar
mainiac2
Default P1166 and P1167 diagnostic code help
My 1998 Honda Accord has these two codes the replacement sensor is $191.00 at the Honda dealership. They are calling it an O2 sensor located under the hood in the exhaust manifold. I took it out yesterday cleaned it up and made sure the electrical connection was clean and tight. Cleared the codes and they came back on within a couple of seconds. Any suggestions would be greatly appreciated.
PS The engine is the F23A4 and Series is EX-ULEV
Thanks Jon
Old Aug 27, 2007 | 08:58 AM
Fuse's Avatar
Fuse
What did you clean it with?
Old Aug 27, 2007 | 09:22 AM
mainiac2's Avatar
mainiac2
Just a small wire brush (brass) and electric clean on the wire connection. Where is the fuse located for this sensor?
Old Aug 27, 2007 | 10:05 AM
totalimmortal's Avatar
totalimmortal
MalleusMaleficarum
There isn't a fuse. Welcome to owning a Honda, sensors are EXPENSIVE and most often Honda specific.
Old Aug 27, 2007 | 11:09 AM
Fuse's Avatar
Fuse
You can track you wires back to the ecm if one is cut or unconnected you are lucky. More than likely you need a new senser. Try a junkyard if the price is high.
Good, electrical cleaner is better than carb or brake cleaners. I have had no luck with cleaning them.
Old Aug 28, 2007 | 03:51 AM
mainiac2's Avatar
mainiac2
thanks for your help guys just measured resistance across power and ground to heater on pigtail and got 320 k ohms, will be buying the sensor today. Jon
