98 accord engine/exhaust problem.
Old Aug 23, 2007 | 02:03 PM
aznmofo247's Avatar
aznmofo247
Default 98 accord engine/exhaust problem.
I was on the interstate the other day and my engine shut off out of nowhere. I coasted to the side of the road and it started right back up with no problem. And today i was driving to my house in my neighborhood and my engine almost shut off but it didnt. The RPMs and MPH meters dropped to zero for a split second and it went back to normal. My maintanence light starts to blink a few times when i start my car.
My check engine light has been on for a while and i got it scanned at autozone. They said it was my egr valve and i went to again later and they said it was my O2 sensor.
Any help??
Old Aug 24, 2007 | 09:22 PM
Fuse's Avatar
Fuse
An o2 senser should not kill the engine but and egr valve stuck open will. The maintenance light just means you need and oil change.
Old Aug 26, 2007 | 08:10 PM
aznmofo247's Avatar
aznmofo247
my engine studder stalled again today. Felt like it choked for a second before catching itself again. Replacing the egr valve a lot of money? is this causing a lot of damage to my car now?
Old Aug 26, 2007 | 11:31 PM
finch13's Avatar
finch13
getting it replaced at a shop is somewhat expensive. maybe get your batt and alternator checked. both of those could make the car stall and the gauge symptom is familiar to dead batteries in my cars and obviously no spark = no enginge runnage
Old Aug 27, 2007 | 05:28 AM
Fuse's Avatar
Fuse
Thy are not that hard to change your self 2 bolts one connector some times a vac line.
Old Aug 27, 2007 | 07:59 AM
aznmofo247's Avatar
aznmofo247
is there a step by step guide and a place where i can get all the parts cheap? Is it as simple as a oil change? I would actually like to do it myself because i want to learn how anyway. Is the egr valve a part that can be bought separately or do i need to buy a package with it, like with the the boot on the axle. I had to replace the entire axle because my boot was cracked and oil was leaking everywhere.
Old Aug 27, 2007 | 08:40 AM
Fuse's Avatar
Fuse
Is it a v6 or a 4 cylinder?
How may times have you throw the egr code?
If it a v6 it has other problems read this.
http://www.tegger.com/hondafaq/tsb/accord/A99-085.pdf
If its a 4 cylinder check hear get your manual.
http://hondatech.info/downloads/Auto/Manuals/Accord/
I like to use oem parts so go to the dealer. EGR valve are one piece no additional peaces need.
Old Aug 27, 2007 | 10:07 AM
totalimmortal's Avatar
totalimmortal
MalleusMaleficarum
It's 138.xx at Honda. I'll be picking one up today.
Old Aug 27, 2007 | 07:55 PM
aznmofo247's Avatar
aznmofo247
its a 4cyl. are u repairing it yourself? if u are than can u help me out too? if its as simple as like changing a tire then i would like to do it..is it just unscrewing some bolts and putting on the new egr valve? i like my parts oem too, so i'll go to the dealership too to get one
Old Nov 20, 2007 | 07:02 PM
aznmofo247's Avatar
aznmofo247
resparking up this old thread because i still havent fixed my car... i took it to autozone a few months ago and got it checked out... the codes i got were:
P0420
P0401
i attached the printouts
if i were to remove my egr valve, do i need to take any certain precautions before i clean it? what should i use to clean it? and for the 0420 code, should i just buy an O2 sensor?
thanks for the help
File Type: jpg
