94 Accord-Speedo intermittent-ABS light on
Old Aug 20, 2007 | 05:20 PM
French's Avatar
French
Default 94 Accord-Speedo intermittent-ABS light on
1) A few months ago my speedometer started not working intermittently. Saw another tread about the possibility of the "vss" being loose. Location of vss?
2) The ABS light comes on after about 10-20 minutes of operation. Any standard service that I can perform? My guess is that some service is required after 225m miles!
Old Aug 20, 2007 | 07:39 PM
Fuse's Avatar
Fuse
VSS is a 3 wire senser on the back side of your trans both problems can be related to a bad vss.
Old Aug 21, 2007 | 04:27 AM
Johar's Avatar
Johar
Its common for the abs to go bad on the 94 accord. Most of the time its a bad abs module, which is too much to be worth repairing.
Old Aug 21, 2007 | 09:36 PM
nspec_Cd5's Avatar
nspec_Cd5
look below the lower coolant hose ( the part where it connects to the engine)
u'll see the VSS. it has 3 10mm bolts. its the only part there w/ 3 bolts
u'll have to take out the intake tube(forgot what its called), but not the coolant hose.
and for the ABS. u're low on the brake fluid (in the abs motor).
look at the abs motor. u'll a little cap. take that out and fill it up w/ brake fluid.
