k24 sensor question need some help !!
okay this is my element, not an accord but a k24 is a k24 and the element forums have about a 3 week turnaround....
so here goes...
okay so i was changing my oil on my 04 element today.... got underneath to loosen the filter and i noticed there was a blue thing hanging down. turns out that there is a broken sensor right above my oil filter im not sure if i broke it trying to loosen the filter from the top or what but regardless i need to fix it.
not sure exactly what it is, i took the car for a ride after letting it warm up after i was all finished with the oil change.... no codes or anything none the less, this is the car that my wife drives and she is out of town mon-fri every week, i dont want to worry taht she will be stranded.
can anybody ID this sensor for me? it is right above the oil filter, you cant really see it from above and it has a blue rubber boot on it. any help is appreciated!
so here goes...
Pic? How may wires? If i had to guess I would say oil senser (your oil light would be on) or knock senser (this would trow a code) so I'm no good. Maybe some thing on your fire wall.
O the vtec pressure switch and vtec solenoid are on the back side. Thy would only code when you try to hit vtec.
