Average Honda Accord Idling RPM
Old Aug 11, 2007 | 01:26 PM
kreizyidiot's Avatar
kreizyidiot
Default Average Honda Accord Idling RPM
What is the average Idling RPM of a 2005 Honda Accord. I have been getting around 600-700 at a full stop on drive, and around 700 on Neutral?
Old Aug 11, 2007 | 09:03 PM
Fuse's Avatar
Fuse
Sounds good. Do you think you are high idling?
Old Aug 11, 2007 | 10:35 PM
fstop128's Avatar
fstop128
my 92 is about there after it warms up. anything under the 1000 isnt that accurate on these tachs. that seems normal.
Old Aug 13, 2007 | 05:42 PM
kreizyidiot
i think its low idling? hrmm...i'm not a car expert so i do not know
Old Aug 14, 2007 | 08:50 AM
JimBlake's Avatar
JimBlake
As long as it idles OK, doesn't stall, & it comes up when you press the gas. If all of that's true, you want it to idle as low as possible. Much below 700 you'll find AC & the larger electrical loads will disturb the idle too much.
Sometimes people want to bump their idle up to 1000 or more just to avoid having to clean & adjust the idle control system properly.
Another reason might be a performance camshaft won't idle well at all under 1000 rpm.
Old Aug 15, 2007 | 07:52 AM
kreizyidiot
Hrmmm
That's cool. My car seems to be okay...so around 600-700 is normal right?
Old Aug 15, 2007 | 08:40 AM
JimBlake's Avatar
JimBlake
I wouldn't jump to conclusions until using an external tachometer that has some accuracy down in that range.
And... notice that the tic-mark for 500rpm is really close to the zero peg, so you also have to be careful how you read it.
If it works good, then it's good.
