best engine oil for high mileage?
Old 07-15-2007, 04:16 AM
wedley2
bboy Wesley West
wedley2's Avatar
castrol GTX is one of thr better dino oils out there. i only use that in my family's cars...
Old 07-15-2007, 04:25 AM
Lemon 84
Lemon 84's Avatar
Thanks for the reply. May I ask, how often do you change your engine oil and its filter? Cheers.
Old 07-20-2007, 12:38 AM
lilneily2005
lilneily2005's Avatar
Default best oil for 94
Hey if you are not using synthetic by now it is too late to change. You will do all sorts of engine damage if you change this late in the game. Just make sure you use the grade exactly as specified on your engine and change it and the filter religiously every 3000 miles or every 3 months which ever comes first. If you are using the same brand for the last 3 oil changes use the same brand just make sure if the engine says 10-30 then you use 10-30 if your engine says 10-40 then use 10-40 if the engine says 5-30 you know what to do by now. The above applys if you are not burning oil. There are additives you can use if you are already burning oil. By the 212,000 on a 94 is not high mileage its just beyond the breakin stage. I know people with hondas properly maintained with 600,000 miles on it and getting ready for a new car due to body rust and the engines are still good.
Old 07-20-2007, 05:24 AM
Johar
Johar's Avatar
This is a really old thread. I dont know why the hell someone brings this stuff back. But just to voice an opinion. Valvoline maxlife non synthetic is best in old engines.
