VSS Wire for 04 Accord 4 cylinder
Old Jun 23, 2007 | 09:41 PM
aejeffor's Avatar
aejeffor
Default VSS Wire for 04 Accord 4 cylinder
In case anyone else is trying to install a navigation system with a VSS lead. It is located just behind the carpet on the passenger side. (To the left of your left foot if you were sitting in the passenger seat)
Just pull the carpet back 6 inches or so and remove the removable plastic cover, you can see the plugs to the individual ecm units. The one you are looking for is on the far right and it is white in color.
The wire is blue and white with two sliver dots on the wire.
I believe it is in position 26.
Tapping into this lead will allow your GPS to more accurately locate your position, and it serves as a quick backup when the signal is lost from the satellites.
I searched everywhere for this information, so I hope this helps someone else that is looking for the same thing.
Edwin
