consol problem???
Old Jun 17, 2007 | 10:26 AM
blindmokey13's Avatar
blindmokey13
Default consol problem???
I have an aftermaket cd player in my car with auxillary output and earlier this week i took out the cd player to plug in the aux for my mp3 player. i got everything back in and turned the car on to see how it works before i start screwing the dash back in and the cd player doesnt work and niether does the cigarette lighter. I have a 1998 accord and was wonder if anyone had any imput on what th problem could be and if it is a fuse then what fuse is it???
Old Jun 18, 2007 | 06:59 PM
nspec_Cd5's Avatar
nspec_Cd5
probably blew a fuse. check under the hood and the fuse box should tell what fuse it is.
It'd probably say radio or something. also check the "back-up radio" fuse
Old Jun 19, 2007 | 09:46 AM
Intrepid241's Avatar
Intrepid241
Yes its a fuse. Check under the hood and on the driver's side.
Old Jun 19, 2007 | 10:36 AM
BetterBob's Avatar
BetterBob
Nobama
Yep, the radio and cigarette lighter are on the same circut.
Old Jun 21, 2007 | 05:28 AM
Johar's Avatar
Johar
Its the fuse for memory. The one that still supplys power if your car is off, for example in the clock. Without it the radio wont work. Its under the hood.
Old Jun 30, 2007 | 03:13 PM
blindmokey13
well the clock works fine i just have to plug it in. I checked the continuity on all the blade fuses in the driverside fuse box and the one under the and they were all closed so i dont know what the problem is.
Old Jul 2, 2007 | 02:43 AM
nspec_Cd5's Avatar
nspec_Cd5
what about the fuse thats right before your stereo?
Old Jul 2, 2007 | 05:08 AM
shane21085's Avatar
shane21085
when the stero was put in did you buy a adaptor harness or just hack it together? if its a hack and crimp job, something may have got crossed and now your deck is fried due to a short
Old Jul 5, 2007 | 12:40 PM
blindmokey13
I bought a wiring harness for the unit. I've taken it out before, checked the wires and the car was off so there shouldn't be any power going to it. Maybe it is fried but i wouldn't think so. I'll have to take it somewhere or something.
Old Jul 7, 2007 | 12:58 AM
nspec_Cd5's Avatar
nspec_Cd5
may be one of your wires came loose when you were putting (may be shoving) it back in.
i guess check to make sure all the connections are good back there, not just the aftermarket harness, but also the factory ones.
