I Need Advice in Replacing Water Pump!
Old Apr 17, 2007 | 09:08 AM
ragingref's Avatar
ragingref
Default I Need Advice in Replacing Water Pump!
I need to replace the water pump in my 1994 Honda Accord LX. Is this going to be a simple or complicated endeavor? If anyone can send me some information on doing this replacement it would be greatly appreciated. Thanks!
Old Apr 17, 2007 | 11:35 AM
JimBlake's Avatar
JimBlake
The waterpump is driven by the timing belt, so you need to look thru the procedure for replacing the timing belt. Check the link...
https://www.honda-acura.net/forums/s...d.php?t=202360
Old Apr 17, 2007 | 12:11 PM
Misa's Avatar
Misa
Pic Whore
have you done any major work on your car?
replacing the water pump requires removing the timing belt (hence why the dealer recommends doing both at the same time). it is not recommended as a first timer DIY on your car
Old Apr 18, 2007 | 02:38 PM
sleezye's Avatar
sleezye
around 30 mins start to finish
