vtec solenoid problems
Old Mar 12, 2007 | 05:30 PM
Shallow_Bay's Avatar
Shallow_Bay
teh accord guy
Default vtec solenoid problems
the past few weeks i've been noticing the engine bogging down around full throttle and in high rpm. i checked for a misfire and found one. that solved that problem.
i took it for another test run right after and noticed the engine was still bogging down, sounding as if i was letting off the throttle because the engine itself got quieter, then louder, then quiter and so on. I came to the conclusion the vtec solenoid is engaging and disengaging itself for some reason. so could this be the solenoid itself or is there some kind of system that controls it? how would i even go about replacing it?
Old Mar 12, 2007 | 10:05 PM
JimBlake's Avatar
JimBlake
Check your oil. VTEC uses oil pressure, and won't work correctly without proper oil pressure.
If it's the VTEC, you'll get a check-engine light. Read the code & tell us what it is.
If no CEL, this can be different things other than the VTEC.
Old Mar 13, 2007 | 03:29 PM
Shallow_Bay
teh accord guy
yup, it was low oil pressure. i found a wicked leak coming from the valve cover gasket. changed that and the oil, runs awesome. thanks guys
