Help kill my alarm?
Old Mar 6, 2007 | 09:13 AM
jwallwork's Avatar
jwallwork
Default Help kill my alarm?
Hey All,
I have a 98 Honda Accord EX Coupe V6. I have had an ongoing problem for about 3 years. I have an aftermarket alarm and a factory installed alarm. My alarm goes off at random times of the day and night. Sometimes 5 times in one day. I have had it into the dealer like 10 times. The aftermarket guys blame the factory alarm, and the dealer blames the aftermarket system. I don't care what the problem is I just want to disconnect both alarms.
Can some one tell me how to disconnect both a factory and aftermarket alarm system. Please help end my frustration.
Thanks,
Josh
Old Mar 6, 2007 | 10:05 AM
ngfriend's Avatar
ngfriend
do u have a valet switch for the car alarm?
Old Mar 6, 2007 | 11:16 AM
scotttharobot's Avatar
scotttharobot
beer here
Do you have a shock sensor on the aftermarket alarm?
Old Mar 6, 2007 | 11:23 AM
jwallwork's Avatar
jwallwork
Default Replies
I have a valet switch but it is busted. All part of the lameness that has been my dealing with this alarm.
And yes it has a shock sensor, if it is armed and I close my trunk to hard it beeps at me as a warning.
Josh
Old Mar 6, 2007 | 04:15 PM
scotttharobot
beer here
I guarantee you your shock sensor is set to sensitive. Mine was on my old car, and the slightest thing would set it off. Try adjusting the sensitivity to the point where only a very hard shock will set it off... i.e. someone breaking a window
Old Mar 7, 2007 | 05:37 PM
k.heiner's Avatar
k.heiner
Well; it seems you should just take your car to the place where your aftermarket alarm was installed, and ask them to remove all of the components... then take it to the dealer and see if they will fix your factory stuff.
Old Mar 8, 2007 | 08:50 AM
jwallwork's Avatar
jwallwork
The aftermarket was put in at the dealership. The issue I have with taking it in is that they want to charge me $80 an hour, with a one hour minimum to disconnect the whole thing. To me that is a ripoff since they couldn't figure out how to fix it in the first place.
Josh
Old Mar 8, 2007 | 09:04 AM
k.heiner's Avatar
k.heiner
Well Josh, I hate to be the one to inform you of this... but they have the upper hand. You can try to remove it yourself, and break something [which will indefinately cost more than $80]. Or you can go to them and pay them $100 bucks to remove it. An alarm install takes about an hour; an alarm uninstall should take less, assuming no complications.
Old Mar 8, 2007 | 09:13 AM
jwallwork's Avatar
jwallwork
Damn them for having the upper hand...
Old Mar 8, 2007 | 10:09 AM
scotttharobot
beer here
Why do you have to go to the dealership?
