Air suspension kit.
Hi guys,
I want to lower my car, but where i live we have a lot of speedbumps.
So i tought about on going for an air suspension kit.
What do you guys think about it?
advantages and disadvantages??
^^^ditto.Just lower it an inch or two with springs and make it stiff.Speed bumps are not that big a problem if you go slow.Lowering springs in my opinion are better easier to install ,nicer ride,you can get a camber kit and not kill your tires,less equipment,and better handling air suspensions are for the low riders.
Sound good to me.Are you going to use a coil over or just a lowering spring.I like springs my self.If you go with ether i would also recommend a camber kit so you dont kill the inside edge of your tire.What year accord?
Never mind 2002 accord rite.You can go with a coil over if you want because you don't have struts you have front shocks.I have dropped a 2002 before i would stay away from the camber adjustable ball joints thy add way to much hight to the upper arm.We where going for 2 inches and the upper arm hits the wheel well,we than had to change to the hole adjustable upper arm for proper clearance.Have fun im out.
