Just ordered component system...what else do I need?
Old Oct 6, 2002 | 03:58 PM
smakdown's Avatar
smakdown
Default Just ordered component system...what else do I need?
Just ordered some infinity 605cs componenets. I know I'm gonna have to cut the back outta the stock bracket, but what else do I need to do? I've read about people using baffles, dynomat, etc... can someone explain that stuff?
Old Oct 6, 2002 | 04:35 PM
VRGNCD5's Avatar
VRGNCD5
cause it's tight!
it would be a good idea to use dynamat and baffles. the baffle will protect the speaker from the elements, wind, rain, dust and dirt. the dynamat will significantly reduce the road noise let into the car and will also reduce any vibrating you may have, and makes your speakers sound quite a bit better.
Old Oct 6, 2002 | 05:03 PM
smakdown's Avatar
smakdown
Ive seen the dynamat stuff at circuitcity, ive also seen speaker baffles at sounddomain, but do you know of any retail stores that carry speaker baffles?
Old Oct 6, 2002 | 07:01 PM
SumAccordGuy94's Avatar
SumAccordGuy94
Older Honda Fanatic
instead of cutting the stock baffles, I recomend making new ones out of MDF and mount the speakers with them... then dynamat the whole door, removing the plastic vapor barrier... then the whole door acts as a "cabinet" for the mid-bass.
Old Oct 6, 2002 | 07:04 PM
dantastic's Avatar
dantastic
cx power!
werd... i made mdf baffles, used a bit of dynamat. gonna put more in later
Old Oct 7, 2002 | 11:09 AM
smakdown's Avatar
smakdown
How do you make mdf baffles?
Old Oct 7, 2002 | 01:30 PM
dantastic's Avatar
dantastic
cx power!
buy some 3/4" mdf from home depot and cut them out thats what i did. used a rotozip. those things suck, i burned my motor, but got a new one under warranty
Old Oct 7, 2002 | 05:06 PM
smakdown's Avatar
smakdown
This might sound kinda dumb, but how do you make a baffle out of mdf?
