Windshield washer spray stopped working..
Old Feb 7, 2007 | 07:31 PM
Black01's Avatar
Black01
Default Windshield washer spray stopped working..
Hi the title says it all. How to fix that? I actually thought that my reservoir was empty, so I bought a gallon. I poured it in and to my surprise that I still have alot of windshield washer solution in the container My car is 01 Coupe LX(4cyl)
Old Feb 8, 2007 | 05:11 AM
fstop128's Avatar
fstop128
can u hear the motor? u r using winter fluid right? has higher alcohol content so its not freezing. if so, then check the nozzles to see if they r clogged or not aimed correctly. use a paperclip. if clear then check the lines from the reservoir to the nozzles. the connection to the back of the nozzles on the hood has to be just right for the tension to work. check and see if u have any leaks esp where the hood meets the fender near the edge of the windshield. i have a 92 and there is a little rubber pc looks like an accordian elbow and it can dry rot and leak it would need to be replaced. happened on a friend's accord.
Old Feb 8, 2007 | 05:53 AM
DarkStarr's Avatar
DarkStarr
Shake n Bake!
make sure the hoses are connected to the nozzles.. went to look at my (female) friends car because hers wasnt working.. and they werent connected!
Old Feb 8, 2007 | 03:57 PM
FallenAngelHIM's Avatar
FallenAngelHIM
yeah my hoses got rock hard solid and stopped connecting, i have to get a new hose but w/e.
Old Feb 8, 2007 | 04:14 PM
totalimmortal's Avatar
totalimmortal
MalleusMaleficarum
I've learned to live without them.
Old Feb 9, 2007 | 08:23 AM
mycb7com's Avatar
mycb7com
Is it below freezing? They could be frozen...
Old Feb 9, 2007 | 07:21 PM
FallenAngelHIM
i should learn so too.
then i can remove my reservoir tank and save 5 pounds and gain .05 WHP
Old Feb 13, 2007 | 06:04 PM
Black01's Avatar
Black01
Thanks for the reply. Anyways I found the problem, the hoses were frozen. Today it warmed up a bit and the nozzle start to work again.
