Rpm drops, car turns off
Old Jan 16, 2007 | 02:22 PM
Denare's Avatar
Denare
Default Rpm drops, car turns off
Hi, I have a honda accord ex auto 94, I'm running into a problem and I don't know what's causing it. Sometimes when I stop at a traffic light all of the sudden the rpm drops and then the car turns off. When I try to restart it right after, it has a hard time starting then turns off again. I have to wait for about 10 minutes then the car will start. This problems also happens when I turn off my car and try to turn it on again right away.
Can anyone help?
Old Jan 16, 2007 | 02:25 PM
F22B Prelude's Avatar
F22B Prelude
Rachel Bilson
EGR
Main Fuel Relay
Old Jan 16, 2007 | 03:02 PM
jammed EGR.
Old Jan 16, 2007 | 03:12 PM
AzNslackerEzT's Avatar
AzNslackerEzT
Banned
How do you fix that problem because my civic had that problem. but now it is just sitting around.
Old Jan 16, 2007 | 04:28 PM
gulfview's Avatar
gulfview
Fuel pump problem?
Loose ignition connection?
Old Jan 19, 2007 | 05:15 AM
again, it's hard to say, but knowing the rep of Accords ... I'm still going with the EGR valve. (The EGR stands for Exhaust Gas Recirculation. Exhaust gas is routed back into the combustion chamber because the exhausted air is much hotter than the intake air. By sending warmer gas into the combustion chamber, the air/fuel mix does not have to do as much work to heat up, and your engine runs more efficiently.)
It has 2 positions, closed and open.
It's "closed" when the car is at normal driving speeds. (0 to 55)
It's "open" when the car is at highway driving speeds.
I'm guessing it is clogged, and is stuck in the "open" position. You're constanly cycling exhaust into your engine, thus bogging and killing it.
Old Jan 19, 2007 | 08:36 AM
bob01721's Avatar
bob01721
Can the car idle at all? If so, it's easy to check for a clogged EGR valve. It has a vacuum line going into it. While the car is idling, disconnect the line at the other end, wipe it off, and "apply vaccum" (ie., suck on it). The car should stall for the reasons e3NiNe described. If it doesn't stall, the valve is "probably" bad.
Old Jan 19, 2007 | 12:24 PM
OptimusPrimeSr's Avatar
OptimusPrimeSr
if you follow bob's instructions, and the valve tests good, might as well give it a good cleansing...(V. EASY).
Old Jan 19, 2007 | 05:48 PM
AzNslackerEzT
Banned
How do you fix that if your car doesn't start anymore?? because mine doesn't start up anymore.
Old Jan 19, 2007 | 06:08 PM
Rebelwork's Avatar
Rebelwork
senile
Can anyone help?
Similiar problem on a 93 Olds Cutlass. Couldnt hear the pump so it was difficult to diagnos the problem.
On the honda you can clearly hear the pump. How long does the pump run when you turn the switch?
Could be the fuel filter. Trash clogs filter,car turns off especially at low rpm's. Car sits, trash settles and drives fine. As soon as the trash loads it shuts down again.
