EGR lift Solenoid!
Old Oct 3, 2002 | 11:54 PM
Ryu's Avatar
Ryu
Team Exgen
Default EGR lift Solenoid! (H22a Swap In Progress)
im currently putting the wiring harness from the accord onto the lude engine...
It turns out my F22B3 engine didnt come with a EGR solenoid so there aint a plug for it....
Basically ill have to take the Ludes plug and run a new wire for it to the ECU along side with the VTEC and IAT sensors...
Getting the pictures developed soon gotta post them up soon...
Right now gotta get a Belt that will fit the crank/Air Cond/ps pump
THe swap guide says 43'' im in australia, so i dunno what that converts to... THe Mitsubishi belt they use on the Lude is a P10 and the Accord one is a P30 i figured that i would need a P25 or P20 to get it to fit properly any ideas?
A Part number for the Belt you guys got would be really helpful i.e from NAPA so i can search it on the web and get its length...
Also has anyone got the belt from the company called Gates? if so a part number would also be helpful
Old Oct 4, 2002 | 01:04 AM
Ryu's Avatar
Ryu
Team Exgen
Looks like i found the belt part number using napaonline and gates...
its actually a 43 1/8'' length
Old Oct 4, 2002 | 11:14 AM
v4lu3s's Avatar
v4lu3s
i ended up just getting a string and wrapping it around the pulleys...measured it, went into the parts store and asked for the one i needed....by size and # of ribs on the belt.
