HELP: cant rev past 3000 rpms
Old Dec 31, 2006 | 04:42 PM
$peed])emon's Avatar
$peed])emon
Default HELP: cant rev past 3000 rpms
all of a sudden i cant go past 3000 rpms in any gear. oil level is fine. what else should i look at? car is a 97 5 spd...thanks
Old Dec 31, 2006 | 04:46 PM
totalimmortal's Avatar
totalimmortal
MalleusMaleficarum
Cel??
Old Dec 31, 2006 | 04:53 PM
$peed])emon
there is no check engine light also..
Old Dec 31, 2006 | 04:57 PM
totalimmortal
MalleusMaleficarum
Have you ever seen the CEL illuminate?? The bulb maybe be burnt out, go to AutoZone and see if a code will pull.
Old Dec 31, 2006 | 09:35 PM
Geowynniv's Avatar
Geowynniv
Default maybe timing
you might want to check your timing belt. I had the same problem with my 98 civic. it wouldnt go over 4000rpm. after i looked at my belt i realized that it had somehow jumped two teeth. so it was readjusted and a valve adjustment was done (becasue it was making a ticking sound for some time) and it has ran fine ever since. just a note from personal experience.
Old Jan 15, 2007 | 04:22 PM
motopsyko32's Avatar
motopsyko32
I had the same problem recently...
https://www.honda-acura.net/forums/s...d.php?t=260373
Old Jan 15, 2007 | 06:30 PM
$peed])emon
i solved my problem but it was not a sensor, it was the starter wtf????
i had starting troubles so i replaced the starter first and then problem was fixed....i dont kno how it is related but it got fixed!
