Turn Signal
Old Dec 22, 2006 | 04:12 PM
b12uceHuy's Avatar
b12uceHuy
Jizz Maste12
Default Turn Signal
Okay I did a search on Turn Signals only came up with 5th gen and nothing i can really use.
Heres my problem my right turn signal will hyper flash when i use it, when i turn on my parking lights it will not flash at all it, the right arrow in the cluster would light up solid Green.
My left turn signal functions perfectly. Could this be a relay problem, if it is where is it located and what part do I need to replace?
Thanks in advance.
Old Dec 23, 2006 | 06:33 AM
v6_accord_jerz's Avatar
v6_accord_jerz
Stupid Power Ball
Hyper flashing is a way of your car telling you that either the front or rear taillight is out.
Old Dec 23, 2006 | 08:54 AM
b12uceHuy's Avatar
b12uceHuy
Jizz Maste12
Nope i checked all the blubs they are all good the filliment is good and when i turn on my parking lights it will not flash at all
Old Dec 23, 2006 | 08:57 AM
mycb7com's Avatar
mycb7com
Do you have bumper lights? Have you inspected the turn signal for bulbs that are burnt out?
Old Dec 23, 2006 | 09:00 AM
v6_accord_jerz
Stupid Power Ball
So the bulb lights up but when you put your turn signal on it does nothing?
These bulbs have 2 filaments. One that stays lit and the other (2nd) lights when your turn signal is turned on.
Your 2nd filament is broke so you still need a new bulb.
Old Dec 23, 2006 | 10:21 AM
b12uceHuy's Avatar
b12uceHuy
Jizz Maste12
Yes both front and rear LEFT turn signal bulbs will light up and light brighter when the brake is applied, but when you try to signal w/ parking lights on it will stay solid (will not Blink). This only is happening on the LEFT signal. The RIGHT Signal lights work fine. I check and replaced all the bulbs with new ones all the blubs are Dual filaments.
Old Dec 23, 2006 | 10:24 AM
v6_accord_jerz
Stupid Power Ball
Did you check your fuses?
Old Dec 24, 2006 | 12:15 PM
b12uceHuy's Avatar
b12uceHuy
Jizz Maste12
Fuses are fine
Old Dec 25, 2006 | 08:58 PM
Stall?'s Avatar
Stall?
Teh slow
Sounds more like a short....
Old Dec 26, 2006 | 09:49 PM
b12uceHuy's Avatar
b12uceHuy
Jizz Maste12
YUP it was a short, the front corner signal light harness was defective. Once it was changed the signal lights worked normal again.
