Radiator fan motor compatibility
Old Dec 7, 2006 | 12:29 PM
XDEep's Avatar
XDEep
Default Radiator fan motor compatibility
tryin to gather some information since i need to fix a noisy radiator fan..
Originally Posted by rage237
it depends on the radiator
i have a 4th gen and there is two differnt rads for mine the only diff is the mounts for the fans, kind dumb i think but hey it sells
Originally Posted by YeuEmMaiMai
94-97 parts will work
usually the fan mounts to the braket and Honda will typically use the same fan motor and just change the mount depending upon applicaton
Originally Posted by CB7VTEC
Just to find out which radiator came with your car, count the blades on your radiator fan (this is the fan closest to the battery you need right?), If you have 4 blades, it's a Toyo rad. If you have 5 blades it's a Denso.
they mount differently because the Accords that came out between 90-93 used different fan shrouds, depending on the different make of radiators that were put in by the factory.
at autozone they sell the fan motor alone for 42$ i think, two different brands.
so my friend's fan is making a noise and i may just buy that instead of figuring out if a used one will fit or not. first i guess i'll try taking it apart and greasing it.
Old Dec 7, 2006 | 12:41 PM
OHS's Avatar
OHS
Banned
Penny wise, dollar foolish. Buy a new one. You'll thank me.
Old Dec 7, 2006 | 10:28 PM
stereo's Avatar
stereo
yes ND or Mitsuba and are used in the accords 90-97 are the same on ND nor sure of the second. unless you know the used one is good it's not worth the trouble for $42. I wouldn't want to do the job over again. but then again I only use Honda parts...
