Passenger Rear Window Stuck
Old Nov 28, 2006 | 07:29 AM
hyperslug's Avatar
hyperslug
Default Passenger Rear Window Stuck
My passenger rear window is fully rolled up and does not respond to either the front driver control or the passenger rear control. There is no noise at all when the switch is pressed.
Is there a fuse for just that window only? How do I check for electrical issues such as continuity? I'd like to eliminate other possibilities before swapping out the regulator.
Old Nov 28, 2006 | 07:39 PM
Fuse's Avatar
Fuse
What year?Regardless their are usually 2 wires running to the window motor.The switches reverse polarity and the motor runs in reverse.So in the up position one wire should have 12v.In the down position the other wire will have 12v.Let me know what you find ,we will get the rite wire diagram and go from there.
If you need help taking off the door panel let me know.
Old Nov 29, 2006 | 09:39 AM
hyperslug's Avatar
hyperslug
It's a 1996 Accord EX, 4DR, 4-Cyl. I took off the door panel to verify that the connector was snug and intact. Do you know of a good source to apply 12V to it to see if it actually does work?
Old Nov 29, 2006 | 12:20 PM
Fuse's Avatar
Fuse
Ya you need to jump power to c673 one 12v one ground see if it works.
Old Nov 30, 2006 | 08:00 PM
hyperslug's Avatar
hyperslug
Wow. Where did you get those pictures? What manual is that? Helms?
Old Nov 30, 2006 | 08:04 PM
Fuse's Avatar
Fuse
Honda manual
Old Dec 1, 2006 | 06:40 AM
mycb7com's Avatar
mycb7com
There are fuses for the windows. Either in the fuse box on the driver side or under the hood.
