Newbie Needs Help
Old Jun 20, 2005 | 04:39 PM
roidzs's Avatar
roidzs
Default Newbie Needs Help
I just purchased a 94 Accord LX Coupe. The interior door lights, cigarette lighter, dome light and vanity mirror light don't work. Also the passenger power window only works from the driver's side, any tips on how to fix these problems, I don't have a clue
Old Jun 20, 2005 | 05:58 PM
M@rshy's Avatar
M@rshy
٩(̾●̮̮̃̾•̃̾)۶
Check the appropriate fuses to see if they have blown. Its most likely the fuses.
03cbr600f4iguy's Avatar
03cbr600f4iguy
check your fuses. for the window, pull out the panel on the door that the window switch is on, and check if the plugs are plugged in.
Old Jun 20, 2005 | 06:15 PM
M@rshy's Avatar
M@rshy
٩(̾●̮̮̃̾•̃̾)۶
Oh! Make sure the child saftey lock for the windows are off.
Old Jun 20, 2005 | 08:40 PM
PikkaGTR's Avatar
PikkaGTR
Power of Dreams
yeah its more than likely your fuses are blown
good luck finding the problems
Old Sep 23, 2006 | 09:59 PM
**Ch!ko 5150**'s Avatar
**Ch!ko 5150**
I had the same problem with my acura. do you have the stock stereo?the reason im asking is becouse if you don't you might want to check the wiring on the stereo. when i check mine the wiring was all f**** up after i did correctly every thing work. now about your window it might be a fuse, the switch might be broken, or your elevetor motor could be burned out..
