98 maintenance
Old Oct 25, 2006 | 04:55 AM
lazyaccord's Avatar
lazyaccord
1998 Honda Accord EX
Default 98 maintenance
ive got a 98 accord ex 4cyl auto. just wondering what the easiest and best things i can do to clean up and improve the life of my engine/transmission
Old Oct 25, 2006 | 08:53 AM
mycb7com's Avatar
mycb7com
Make sure you change the engine and transmission oil on time. Make sure your oil is a light-clear brown, and make sure your transmission fluid doesn't smell burnt.
Old Oct 26, 2006 | 08:34 AM
JimBlake's Avatar
JimBlake
Those auto trannies aren't known for being the most durable. You may want to change tranny oil more often than the 'official' schedule. Some people around here do tranny drain/fills every 20k or 30k miles.
Use 'genuine' Honda ATF, they seem to be work better like that.
Don't have your tranny 'flushed'. They don't seem to like the solvents or whatever is used by the flushing machine. If the fluid looks or smells bad, you can do several drain/fills & drive around (10 miles?) inbetween. The torque converter never drains, so you can only drain 1/3 or 1/2 of the total fluid.
Old Oct 26, 2006 | 06:53 PM
losiglow's Avatar
losiglow
Get a hayes manual. It will tell you all the stuff recommended at different mileage intervals. Oil change, tranny fluid change, air filter, etc. There's a ton of crap you might not even think of. PCV valve, coolent system flush, spark plug replacement, checking/cleaning electrical components (distributor, wires, battery terminals, etc), check/replace hoses and belts, brake system check (pads, rotors, fluid) cabin filter (so the inside of your car doesn't start smelling like wet dog), cleaning off exceess grime from the engine and components, the list goes on. Get one of those manuals. It'll keep you busy .
Old Oct 30, 2006 | 05:31 AM
lazyaccord's Avatar
lazyaccord
where can i get a hayes manual?
Old Oct 30, 2006 | 06:31 AM
Misa's Avatar
Misa
Pic Whore
Helms > Hayes
http://www.helminc.com/helm/product2...V90GDC0JMBDW37
Helms are the same manuals Honda Techs use... if you can save 1hr of labor... the manual pays for itself.
Old Oct 30, 2006 | 10:16 AM
98CoupeV6's Avatar
98CoupeV6
lots and lots of fail
Originally Posted by Jani
Helms > Hayes
:werd:
Haynes is great until you can't find a torque value or there's a key step missing.
Old Oct 30, 2006 | 09:11 PM
AJē06's Avatar
AJē06
I need a cabin filter... its already too late for meeee...
Old Oct 30, 2006 | 09:18 PM
Misa's Avatar
Misa
Pic Whore
you dont have one
