Engine revs while in park: 1999 Accord coupe
Old Oct 4, 2006 | 12:24 AM
tyrone's Avatar
tyrone
Default Engine revs while in park: 1999 Accord coupe
***To start off, my vehicle had not been driven for 3 months while it was being shipped overseas (military)***
While the car is in park, the engine will rev up and down between 1k rpm and about 2.5k rpm, or stay reving around 1k rpm. When in drive and I come to a stop on level ground then let my foot off the brake, the car will accellerate up to almost 20 mph without even touching the gas. Also, if I engage the parking brake (which i know is good) while in drive on level ground, the car will try and go forward with the back brakes locked up, like if I were pressing the gas. Listed below are some other problems that I've encountered since receiving my vehicle that might aid someone. Any information on what might be the problem will be greatly appreciated since I'm in a foreign country and its kinda hard to get work done on vehicles without them ripping you off or adding more problems.
- engine runs really hot
- A/C doens't work, blows hot air out of one vent
- problems with CD player, automatic seats, and cruise control
- factory security alarm will not engage from remote (brand new battery in remote)
Old Oct 4, 2006 | 07:52 AM
Black01's Avatar
Black01
I cant help you with all of the problems in your list but I can help you with your A/C, go to an auto shop and tell them to recharge your freon. If they do, your A/C should be back in business
Old Oct 4, 2006 | 08:35 AM
98CoupeV6's Avatar
98CoupeV6
lots and lots of fail
:doh:
Cars haven't used freon for 15 years. The 6th gen Accord uses R-134a as a refrigerant.
Anyway...the A/C could be a lot of things, as could other stuff. I recommend you buy a Helms service manual and troubleshoot them or take it to a Honda dealership.
The idling problem has been discussed hundreds of times on here, so do a search...it could be an EGR problem, maybe you just need to run some seafoam throught he engine, maybe some lucas fuel injector cleaner, etc.
Old Oct 4, 2006 | 09:12 AM
AccordingToThis's Avatar
AccordingToThis
I had a problem where my '91 Accord would rev while in park. All it needed was some lubricant to unstick the throttle cable.
Old Oct 4, 2006 | 01:13 PM
idol4232003's Avatar
idol4232003
regarding the engine behavior...did u notice if the "check engine" light came on? if it did, u may wanna find out the code and go from there...
Old Oct 4, 2006 | 02:17 PM
Black01's Avatar
Black01
Originally Posted by 98CoupeV6
:doh:
I'm sorry man, will you forgive me for my mistake?
There you go! The man has given you the correct answer. Anyways my last car(1994) had the same problem and it was still using FREON but I'm telling you it wasn't 15 years ago and my ex-gf's car which is a 1997 still uses FREON. Do the math.
Old Oct 4, 2006 | 02:24 PM
98CoupeV6's Avatar
98CoupeV6
R12 Freon was banned in 1995.
Old Oct 5, 2006 | 04:36 PM
MTEng's Avatar
MTEng
I have almost 20# of it in my garage... use it in my beater Toyota and my 91 HB Si
IACV gummed up???? Does it do it when hot, cold or both?? [see below, too, could be the hot engine]
Thermostat?? Low coolant?? Cooling fan(s) inop?? Does it run cool when moving at highway speed?? Bad temp sending unit?? Bad temp sending unit (may be more than one) with throw all the ECU calcs off and it can run like crap.
All the factory CD players suck. What's wrong with the seats and cruise??
Did the thing run OK before you put it on the slow boat to China???
Old Dec 16, 2006 | 12:40 PM
david_h_b's Avatar
david_h_b
Default My 2000 accord V6 does same thing
In park, it revs from 1k rpm to 2k rpm and back . I am investigating.
Old Dec 17, 2006 | 10:59 AM
gulfview's Avatar
gulfview
The most likely culprits are:
1. Throttle position sensor (TPS)--usually has to be replaced along with the throttle body
2. Idle Air Conrol Valve -- a good cleaning might do it
3. a vacuum or air leak someplace by the intake manifold
