clutch fluid leak?
Old Oct 3, 2006 | 05:38 PM
idol4232003's Avatar
idol4232003
Default clutch fluid leak?
im not sure how to address this, but i need some input..so here goes...
i have a 95 accord ex (4cyl, MT). if i don't use it for a long time (say 2 weeks or longer), the clutch fluid reservoir becomes empty eventually, and i lose hydraulic pressure in the system (i.e., air gets in the lines). now, my first suspicion is a leak somewhere in the system...BUT if that's the case, how come i dont see this problem when i use the car regularly (every other day or so)
thanks for input...
Old Oct 3, 2006 | 07:37 PM
simplyredvw's Avatar
simplyredvw
It's just a slow leak that takes time. Check the slave and master cylinders for signs of leakage. I'll go with the master cylinder on this one.
