5th gen rear speaker installation problem
Old Oct 2, 2006 | 06:53 PM
gq_fuzion's Avatar
gq_fuzion
Default 5th gen rear speaker installation problem
i just got a set of MTX Thunders from futureshop...
tried to install them tonight... but found that the holes don't line up...
the stock speakers have longer holes than the MTX's i just purchased...
how would i install these?
Old Oct 2, 2006 | 07:33 PM
totalimmortal's Avatar
totalimmortal
MalleusMaleficarum
Longer holes???
Old Oct 3, 2006 | 04:31 AM
Originally Posted by totalimmortal
Longer holes???
I'm guessing the mounting holes on the OEM speaker bracket is more of an oval than a circle shape. A few CM's go a long way.
To install your new speakers, you'll have to rotate the speaker in a position where you can drill 4 clean, new holes.
or ghetto rig it with zip ties.
Old Oct 3, 2006 | 04:58 AM
gq_fuzion's Avatar
gq_fuzion
exactly...
at least you didn't recommend double sided tape like my buddy
zip ties i guess work better than double sided tape
any other recommendations?
i'm not looking to drill any new holes in the vehicle...
speakers maybe... i've tried longating the holes already without much success
Old Oct 3, 2006 | 06:34 AM
totalimmortal
MalleusMaleficarum
I installed a pair of Alpine Type-S just fine in my cousins 5th Gen. Buy some alpine's.
Old Oct 3, 2006 | 04:44 PM
starky34's Avatar
starky34
94 Accord Lx 5-speed
abs plastic would do just fine see
Old Oct 3, 2006 | 10:49 PM
scotttharobot's Avatar
scotttharobot
beer here
just get some self-tapping screws.. what's the big deal?
Old Oct 4, 2006 | 06:25 AM
gq_fuzion's Avatar
gq_fuzion
thanks for the advice... but would only work if the speaker was smaller...
unfortunatly... my holes are on the outside of each hole... so larger diameter
Old Oct 4, 2006 | 06:46 AM
gq_fuzion's Avatar
gq_fuzion
i'm sorry if my question seems amateur and/or offends you
i'm merely trying to collect advice on the best method of tackling this issue
Old Oct 4, 2006 | 08:19 AM
starky34's Avatar
starky34
no what i did was took off that plate that held the stock speakers in and then put the plastic into the holes that held in the plate those are 6x9 you should be able to fit your speakers in doing that
