Whats Going On.
Old Sep 26, 2006 | 12:27 PM
dwajt's Avatar
dwajt
Default Whats Going On.
If anyone has an f22b engine that seems to knock upon start up, then deminishes quite a bit after 10-15 min. please write reply as to what it is. loud at low rpm,quite at high. Sounds like its near the top but untrained ear doesnt help. Like a little diesel motor in the morning.
Old Sep 26, 2006 | 12:32 PM
t3t4delsol's Avatar
t3t4delsol
check tps and iacv
Old Sep 26, 2006 | 01:24 PM
dwajt's Avatar
dwajt
Ill do that,thank you. Do you think one of these sensors is causing detonation? Because it sounds mechanical. I will check them out regardless. peace out.
Old Sep 26, 2006 | 05:22 PM
Shallow_Bay's Avatar
Shallow_Bay
teh accord guy
every f22b engine i've ever seen has made this noise after about 90k... its normal. a valve clearance adjustment usually helps it, but probably wont completely get rid of it. also consider using synthetic motor oil.. that seemed to help a bit.
Old Sep 27, 2006 | 10:22 AM
dwajt's Avatar
dwajt
It drives me nuts though! I have had tune up kit put in, Timing belt(s) kit put in, and had valves adjusted. Mechanic said they were barely out of adjustment. Fuel cleaner, oil adatives, but to no avail. Is it the cam bearings? rocker pivots?
Old Sep 27, 2006 | 05:58 PM
Shallow_Bay
teh accord guy
i was also thinking it could be the rocker pivots... since they make this noise on alot of cars, not just accords.
Old Sep 28, 2006 | 07:58 AM
dwajt's Avatar
dwajt
Thanks for the input. Can I take off rocker cover and inspect pivots,cam bearings? If so how can I do this?
