e-brake and TCS lights on? Why?
Old Sep 25, 2006 | 06:35 PM
Ramman949's Avatar
Ramman949
Default e-brake and TCS lights on? Why?
I got a 2003 V6 EX accord and the the ebrake and TCS light recently turned on and it wont turn off. The rear pads are 4 months old. I changed the front ones today because they looked a little low, but not even near the wear indicator. I also checked the e-brake switch under the handle to make sure that wasnt broken. And finally I checked the fluid which is right at the top of the full mark. Yet the darn light stays on. I even pulled my negitive and reset the ECU and still its on. All wheel sensors are in place. What could be causing this? I also used one of those obdII ecu readers and it said I have no codes? But someone mentioned to me that I need a different code reading tool?
The ebrake will stay light upon startup. Within 1 minute, the TCS light comes on.
Old Sep 25, 2006 | 08:21 PM
Misa's Avatar
Misa
Pic Whore
03..... are you still under warranty?
Old Sep 25, 2006 | 09:51 PM
Ramman949's Avatar
Ramman949
Drivetrain only.
Old Sep 25, 2006 | 10:19 PM
Ramman949's Avatar
Ramman949
Any mechaincs on here? Anyone with simular issue? Anything???
Old Sep 26, 2006 | 09:38 AM
Ramman949's Avatar
Ramman949
bump for help
Old Sep 26, 2006 | 10:55 AM
stereo's Avatar
stereo
it's on because your ebrake light stays on check your brake fluid. the TCS thinks your driveing with the ebrake set!
Old Sep 26, 2006 | 07:27 PM
Ramman949's Avatar
Ramman949
"^^^^^^I checked the fluid which is right at the top of the full mark. "
Old Sep 28, 2006 | 08:27 AM
stereo's Avatar
stereo
try unplugging the wire on the cap of the brake master if the light goes out then replace the cap.
Old Nov 1, 2007 | 06:35 PM
12guns's Avatar
12guns
I know it's an old thread, but my v6 2003 did the same thing, turned out to be rear speed sensor and abs sensor, was under extended warentee but normally ran about $400
