Moron issues: wrong oil filter...
Old Sep 22, 2006 | 12:08 PM
ND120883's Avatar
ND120883
Default Moron issues: wrong oil filter...
So I grab a filter off the Fram XG3593 oil filter section of the shelf. I get home and put the filter on...only to realize that there had been an XG 3506 filter in that same spot.
From what I can tell, it's identical. Same dimensions and it even threaded on perfectly. There is no oil coming out of the seal after a few minutes running it. No obvious problems. I just wanna make sure I'm okay...
Old Sep 22, 2006 | 02:01 PM
wedley2's Avatar
wedley2
bboy Wesley West
it seems like you solved your own problem
Old Sep 22, 2006 | 02:46 PM
flatlandtacoma's Avatar
flatlandtacoma
2004 Accord EX-V6
3593 thread 20x1.5mm
gasket od 2.475 id 2.173 th 0.233
3506 thread 13/16-16
gasket od 2.734 id 2.430 th 0.226
Those two filters aren't really interchangeable. The threads are close but not exact and the gaskets are way off. If it were me I would put the correct size on ASAP.
Old Sep 22, 2006 | 07:48 PM
moky's Avatar
moky
true! that would have been a major problem for you if it starts kicking out oil or destroying your threads.
Old Sep 22, 2006 | 09:03 PM
ND120883's Avatar
ND120883
well i had no issues threading it at all. If that had happened I'da taken care of it. Drove it for several hours tonight...no problems.
The oil's far enough down in the sump that I can just change the filter without worrying about draining it all...right?
Old Sep 23, 2006 | 04:15 AM
flatlandtacoma
2004 Accord EX-V6
Correct. You will only lose what is in the filter, maybe 10 or 12 ounces of oil.
Old Sep 25, 2006 | 11:40 PM
ND120883's Avatar
ND120883
Update:
Replaced the 3506 filter. I looked it up on the guide, turns out they use these things on corvettes? Anyways, took the 3506 off, put the 3593 proper filter on and no problems. Apparently a 3506 will work in a crunch, cause it didn't mess anything up.
THANK GOD.
