remote oil filter
Old Sep 19, 2006 | 03:11 AM
mjsparky363's Avatar
mjsparky363
Default remote oil filter
anyone know if there is a kit to relocate the oil filter on a 05 tsx to a better location so oil doesn't go all over every time you change the filter?
Old Sep 19, 2006 | 11:17 AM
Misa's Avatar
Misa
Pic Whore
theres no kit.... you'd have to go custom.
Old Sep 19, 2006 | 11:37 AM
flyromeo3's Avatar
flyromeo3
Im sure you have thought of this but, normally I use a rage to clean up any excess spillage.
Old Sep 19, 2006 | 11:44 AM
98CoupeV6's Avatar
98CoupeV6
lots and lots of fail
Where are you from? I grew up in Saratoga.
Anyway...if you're careful you won't make a mess at all. It's taken me awhile but on my V6 I've fnally gotten the hang of it. Just buy one of those disposable $5 oil change kits and set it under the filter after you drain the oil out of the block, you'll be all set.
Old Sep 19, 2006 | 09:35 PM
simplyredvw's Avatar
simplyredvw
You obviously haven't worked on a TSX. That damn intermediate shaft gets in the way and you will get oil spillage in some very odd nooks and crannies. I usually put a piece of cardboard over the intermediate shaft and use it to funnel most of the oil into a drain pan.
Old Sep 20, 2006 | 01:07 AM
SumAccordGuy94's Avatar
SumAccordGuy94
Older Honda Fanatic
make sure the block is drained first, that will help. You can easily clean up any dripped oil with brake cleaner when you're done.
