please help! a/c and radio lights
Old Sep 17, 2006 | 06:31 AM
ed_atoigue's Avatar
ed_atoigue
Default please help! a/c and radio lights
Hey guys i got a 2003 accord ex... the radio lights and climate control lights went out....the a/c and radio still work....any suggestions on how to fix it.....please help! email me at ed_atoigue@yahoo.com... thanks
Old Sep 17, 2006 | 07:33 AM
jerry00's Avatar
jerry00
go to a honda dealer and ask for a light bulb for the a/c and one for the radio then install them...you'll be fine.
Old Sep 17, 2006 | 12:38 PM
ItsaHonda's Avatar
ItsaHonda
Very common issue with the 03-04s and the problem was not with the bulb. Honda has replaced quite a few of these under goodwill, so check with your local dealership first and if you don't get results, call HOA. The shop will replace your entire headunit (but will reuse the face plate) and as far as I know, this is the only solution to the problem. If you're stuck having to foot the bill, either deal with having no lights or caugh up the $1,000+ to replace it. I would recommend a used unit, but if it's out of an 03-04, it'll eventually go out on you again. Good luck.
Old Sep 17, 2006 | 01:04 PM
scanrps's Avatar
scanrps
Honda Parts Tech
Like he said, see the dealer. Even if its out of warranty, or no HondaCare,
we still replace several with DSM approval. So push the issue, Honda
knows it has a problem.
Old Dec 9, 2007 | 07:11 AM
import12's Avatar
import12
Had same radio lighting prob, my Honda dealer replaced the circuit board free of charge at 92,000 miles. Honda is aware and has extended the warranty for this particular problem to 100,000 miles.
-Forrest, Fort Worth
