lip kit instalation help
Old Sep 6, 2006 | 03:41 PM
ColeM's Avatar
ColeM
Banned
Originally Posted by aznpimpin89
okay okay, i basically know how to mount it on and stuff, but the lip doesnt fit. i can force it on, but the sides will rip off since its plastic. or is that how its supposed to be? theres no other way to put it on unless i stretch it
i have one of my 95 just slide each end on then put the screw threw the end (take off factory lip) then the bars u put under the lipbolt um on then pull the lip tight and bolt it somewhere on your existing bumper...thats how i did it
Old Sep 6, 2006 | 04:13 PM
aznpimpin89's Avatar
aznpimpin89
does everything fit on tight? because for mine, i see some gaps. also, did your sides tear a little?
Old Sep 6, 2006 | 05:43 PM
ColeM's Avatar
ColeM
Banned
Nah, didnt tear i had to buy more L brackets....with enought itll work lol.
Old Sep 7, 2006 | 04:28 AM
flyromeo3's Avatar
flyromeo3
again......double sided tape.
Buy some 3M heavy duty tape. It will hold.
Old Sep 7, 2006 | 04:49 AM
Misa's Avatar
Misa
Pic Whore
where did you buy the lip?
Old Sep 7, 2006 | 04:51 AM
I installed a rear lip on my bumper.
there are paper templates on where to DRILL HOLES. Be really careful, triple check everything, start with a small bit, and work your way up.
You can STOP short of the 8 or 10mm hole needed. It'll just make it tighter.
When drillling, use a fast speed dremmel to start a pilot hole. If you go slow, you might spiderweb the paint.
Old Sep 7, 2006 | 07:24 AM
flyromeo3's Avatar
flyromeo3
i have the mugen style rear lip on my 02 sedan and had no problems putting it on
I used 3M tape and its holding. No screws needed. Also, I didnt run into any problems with it fitting.
Did you get it from ebay too?
Old Sep 7, 2006 | 04:47 PM
aznpimpin89
yeah, i got it on ebay. when i try to put on the rear lip, like, the sides that you drill onto the back bumper wont fit. you have to really really stretch it. theres like a 1 centimeter gap. ive tried to force it on, but it ripped so i stopped trying.
Old Sep 7, 2006 | 04:48 PM
aznpimpin89
can you send me pics?
Old Sep 7, 2006 | 05:37 PM
Misa's Avatar
Misa
Pic Whore
the problem with ebay stuff is that theres no quality control for generic stuff.
