Coolant Leaking!! HELP ME! 03 Accord Coupe
Old Aug 31, 2006 | 07:42 PM
Shortynick09's Avatar
Shortynick09
Default Coolant Leaking!! HELP ME! 03 Accord Coupe
I just noticed that i got a Coolant Leak in my 03 accord Coupe v6 . I cant find where its coming from...I start the car and let it run for a bit and then i see the temp. is going up soo i shut down the car not to overheat the engine . and open the hood and notice that coolant is allover my driveway and Soo could any HELP ME OUT!!
Old Aug 31, 2006 | 07:55 PM
simplyredvw's Avatar
simplyredvw
Fill up the coolant, leave the hood open, start the engine and leaving it running. Look under the hood and try to locate the leak or it's proximity to other items.
That's the best I can give with those details.
Old Aug 31, 2006 | 07:58 PM
Shortynick09
Default thx but i tried that ..and its steaminy!
i tried that and still cant locate where its coming from!
Old Aug 31, 2006 | 08:00 PM
simplyredvw
Anymore clues as to the location of the leak in relation to the engine compartment (ie, towards the front, on the right, etc.).
Old Aug 31, 2006 | 08:02 PM
Shortynick09
Default Thx
ITS LEAKING FROM THE LEFT UNDER THE RADIATOR! ANY CLUES? aSLO COULD I START THE ENGINE WITHOUT ANY COOLANT?
Old Aug 31, 2006 | 08:12 PM
simplyredvw
Check your radiator for any signs of damage, such as rock hits. I would be surprised if the hoses are bad unless you have a lot of mileage on the car. You should also check to make sure that the radiator drain petcock is tight. You can start the engine without coolant but you shouldn't let it run too long.
Old Aug 31, 2006 | 08:15 PM
Shortynick09
Default thx
is thier anyway i can repair the RADIATOR if thats the problem?
thanx NicK!
Old Aug 31, 2006 | 08:16 PM
simplyredvw
thanx NicK!
Usually not, it has to be replaced if you are looking for a long term fix.
Old Aug 31, 2006 | 08:19 PM
Shortynick09
Default thx
could i like to check with just regular water and put it into the RADIATOR and and see if it can work?
Old Sep 1, 2006 | 07:54 AM
TaekOne's Avatar
TaekOne
pronounced tech
i dont have anything really useful to say except make a suggestion that you learn to speak/use real english
