am i burning oil?
Old Aug 10, 2006 | 03:30 PM
niqtorious's Avatar
niqtorious
Default am i burning oil?
i just got an oil change like a month ago and today i noticed i was really low on oil... do you think im burning oil? i dont smell it or anything and theres no leaks but could it be possible?
or did i just get screwed by the oil change place?
Old Aug 10, 2006 | 04:34 PM
RatedITR55's Avatar
RatedITR55
I
Do you notice any black spots underneath your car? If so, you're probably leaking oil.
Old Aug 10, 2006 | 05:33 PM
v6_accord_jerz's Avatar
v6_accord_jerz
Stupid Power Ball
If you were burning oil i believe you'd see blueish smoke come out ur exhaust....i know white smoke is coolant.....you probably just gotta leak somewhere
Old Aug 10, 2006 | 09:15 PM
niqtorious's Avatar
niqtorious
theres nothing on the driveway tho
Old Aug 10, 2006 | 11:02 PM
Phateless's Avatar
Phateless
S2K compatible
yeah/miles of car? condition? when did you check it? were you on a flat surface? if you check your oil immediately after turning the car off you'll get a faulty reading because the oil has to drip back down.
Old Aug 11, 2006 | 11:05 AM
prostang460's Avatar
prostang460
You could be burning oil and the converter could be stopping most of the smoke.
Maybe when the oil was changed the .5 quart that it takes to fill the oil filter wasn't accounted for. This is usually the case at most quick lube places.
Old Aug 11, 2006 | 11:11 AM
oholdeno's Avatar
oholdeno
why don't you just fill up the oil to the level you need and see if it changes afterwards?
Old Aug 11, 2006 | 11:17 AM
totalimmortal's Avatar
totalimmortal
MalleusMaleficarum
If your car is VTEC, VTEC acutaion burns oil. If you find yourself in the upper RPM's a lot, you'll burn a bit of oil. I know since I got my test pipe, I blow a smidge of bule smoke at the top of gears.
Old Aug 11, 2006 | 12:06 PM
Phateless's Avatar
Phateless
S2K compatible
when i drove behind my gsr after i first got it, i saw a small puff of black smoke every time my friend hit vtec. i assume that's just cuz the previous owner never wound it up tho.
Old Aug 11, 2006 | 01:12 PM
totalimmortal
MalleusMaleficarum
That's true. Bringing it to redline every so often burns the carbon of the valvetrain.
Visheetal
92+ Civic/EL & Del Sol
6
Mar 31, 2006 08:59 AM
Unlimitation
Sep 1, 2005 12:58 PM
b18c1_hatch
5
Sep 1, 2004 04:39 PM
huviduc
22
Jan 24, 2004 05:23 PM
rydnby 4
5
Jun 24, 2003 10:33 PM
