accord dent removal
Old Aug 1, 2006 | 04:25 AM
flyromeo3's Avatar
flyromeo3
Default accord dent removal
Hey guys, I got a dent (if I make a fist my knuckles kinda cover it ) and im trying to remove it. Its right along the the lining where my hood meets the left fender. I bought that ding king but for some reason the glue wont stick right I guess cause of where the dent is.
If I take off the fender would I be able to roll it out?
Maybe heat up the inside with a blow dryer and push it out?
Old Aug 1, 2006 | 05:17 AM
v6_accord_jerz's Avatar
v6_accord_jerz
Stupid Power Ball
Heating with a blow dryer won't work.....but what might work is if you take the fender off and try to tap it out the best you can.....not sure what it looks like but doesn't sound too bad
Old Aug 1, 2006 | 05:19 AM
bradsmit's Avatar
bradsmit
I have a dent in the exact same spot and same size, Ithink some bone heads hit it with a baseball on my street. Woul dbe interested on some removal ideas before I just go to a body shop
95 Accord V6
Old Aug 1, 2006 | 06:13 AM
totalimmortal's Avatar
totalimmortal
MalleusMaleficarum
tapping it out would be about as far as you can go before a repaint would be required. It's actually the first step most body shops use to remove dents, then all the prep work.
Old Aug 6, 2006 | 12:37 PM
Hondapower80's Avatar
Hondapower80
Try PDR (paintless dent removal). They have special tools to try to pop it out, but from your description and the angle, you might be SOL. Give them a try and ask for an estimate.
Old Aug 6, 2006 | 06:25 PM
burnrubber's Avatar
burnrubber
Nucking Futs
if that dont work try a heat gun and gently push it out
