93 Accords and O2 Sensors
Old Jul 25, 2006 | 11:57 AM
fumesdeuce's Avatar
fumesdeuce
Default 93 Accords and O2 Sensors
I've seen several posts about replacement O2 sensors, benefits thereof, etc. I had the CEL and all that, diagnosed as O2 sensor. 277K miles, never replaced before now. They wanted my first born for the Honda part. Autozone, got the Bosch, installed. Fixed the problem, got great gas mileage at first, probably first couple of tanks. Now gas mileage has "tanked" and the car feels sluggish sometimes. Still very driveable and no CEL yet, but something ain't right. Any ideas? Am I due for the Honda part?
:wtf:
Old Jul 25, 2006 | 12:00 PM
F22B Prelude's Avatar
F22B Prelude
Rachel Bilson
Plugs, Wires, Cap, Rotor ?
Old Jul 29, 2006 | 02:49 PM
TypeG's Avatar
TypeG
probably cause it's african hot outside, but yeah, check on a tune-up. later.
Old Jul 29, 2006 | 11:09 PM
fstop128's Avatar
fstop128
catalytic converter. if u have never changed the 02 sensor a bad one will destroy the converter. if u have changed the converter then try the pcv valve and air filter. the high heat and humidity with the gasoline blends on the market can mess things up too. the higher alcohol content in the gas makes the earlier hondas not run well. oil cos add alcohol to make engines run leaner and they also use it as a cheap way to increase the octane.. so u burn it faster and it doesnt help the engine any. makes it run like crap. it could also be that u r using a bosch sensor. older hondas do better with ngk/ntk or denso sensors. ngk makes the oem for honda.
